Libraries no longer updating
Version 1.14.1.5488, does not update libraries since recent changes.
It seems to start the scan process, then immediately aborts it.
Please help
My solution on windows was to delete effected library an add it again.
Then the scanner picked up new files.
I too am running PMS Version 1.14.1.5488 and having no luck with updating libraries anymore.
I have a VERY simple setup …
  • Windows 10 Server - version 1803 - build 17134.523
  • file share mounted as Z: drive which is a western digital mycloud 1TB storage
… that’s it!
It all of a sudden is no longer finding ANY new media anywhere. I am trying to rip new episodes of MASH into the TV Shows folder but PMS is not picking them up. My folder structure looks like:
z:\media\TV Shows\MASH\Season01\Mash-s1e01.m4v
where Season01 has Season 02, 03, etc as separate folders. Everything was good until I added a folder for Season10 and its associated episodes. No luck it will not pick up the media no matter what I do.
Here are my debugging steps:
  1. Create different “season” folder under original location aamed “Season-10” --> No luck
  2. Create different “TV Shows” folder named “TVShows” and move the new “Season-10” folder with one episode in it to that folder. Create a new TV Shows library and point it at the “TVShows” top level folder --> No Luck
  3. Move “Season-10” folder to local hard drive (C:) under folder structure of:
    C:\Users\bill\Desktop\TVSHOWS\MASH Episodes\Season-10\ —> No Luck
Here is the log file from the first scan of that folder. I’m not a 100% on how to read the output here but it sure looks like it found something in the folder and scanned it but it is just not showing up in the interface.
Jan 17, 2019 20:36:44.294 [2204] INFO - Plex Media Scanner v1.14.1.5488-cc260c476 - Microsoft PC x64 - build: windows-i386 - GMT -05:00
Jan 17, 2019 20:36:44.294 [2204] INFO - Windows version: 6.2 (Build 9200), language en-US
Jan 17, 2019 20:36:44.295 [2204] INFO - 4 2594 MHz processor(s): Architecture=0, Level=6, Revision=14857 Processor Identifier=Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
Jan 17, 2019 20:36:44.295 [2204] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe” --scan --refresh --section 12
Jan 17, 2019 20:36:44.239 [2148] VERBOSE - [FFMPEG] - Rescanning for external libs: ‘C:\Users\bill\AppData\Local\Plex\ Media\ Server\Codecs\531e313-1328-windows-i386\’
Jan 17, 2019 20:36:44.242 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\aac_decoder.dll
Jan 17, 2019 20:36:44.243 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\ac3_decoder.dll
Jan 17, 2019 20:36:44.244 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\h264_decoder.dll
Jan 17, 2019 20:36:44.245 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\libmp3lame_encoder.dll
Jan 17, 2019 20:36:44.246 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\libx264_encoder.dll
Jan 17, 2019 20:36:44.282 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\mp2_decoder.dll
Jan 17, 2019 20:36:44.289 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\mp3_decoder.dll
Jan 17, 2019 20:36:44.290 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\mpeg4_decoder.dll
Jan 17, 2019 20:36:44.291 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\msmpeg4v3_decoder.dll
Jan 17, 2019 20:36:44.292 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\wmav2_decoder.dll
Jan 17, 2019 20:36:44.293 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\wmv2_decoder.dll
Jan 17, 2019 20:36:44.294 [2148] VERBOSE - [FFMPEG] - Loading external lib C:\Users\bill\AppData\Local\Plex Media Server\Codecs\531e313-1328-windows-i386\wmv3_decoder.dll
Jan 17, 2019 20:36:44.295 [2148] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
Jan 17, 2019 20:36:44.741 [2148] DEBUG - Scanning TV using en(Plex Series Scanner) with 0 current media items and 1 section locations in the database…
Jan 17, 2019 20:36:44.745 [5824] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=12&sinceTime=1547774204
Jan 17, 2019 20:36:44.762 [5824] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=12&sinceTime=1547774204
Jan 17, 2019 20:36:44.980 [2148] DEBUG - Performing a scan with ‘Plex Series Scanner’ (language: en virtual: 0).
Jan 17, 2019 20:36:44.980 [2148] DEBUG - * Scanning C:\Users\bill\Desktop\TVSHOWS
Jan 17, 2019 20:36:44.981 [2148] DEBUG - * Scanning directory C:\Users\bill\Desktop\TVSHOWS (parent: no)
Jan 17, 2019 20:36:44.996 [2148] VERBOSE - * Noting that ‘’ was updated at 2019-01-17 20:35:29
Jan 17, 2019 20:36:44.996 [2148] VERBOSE - * Taking directory ‘’ (1729) out of the map (0 left)
Jan 17, 2019 20:36:44.997 [2148] DEBUG - Adding subdirectory for scanner: “C:\Users\bill\Desktop\TVSHOWS\MASH Episodes”
Jan 17, 2019 20:36:45.000 [2148] DEBUG - * Scanning directory C:\Users\bill\Desktop\TVSHOWS\MASH Episodes (parent: yes)
Jan 17, 2019 20:36:45.014 [2148] VERBOSE - * Noting that ‘MASH Episodes’ was updated at 2019-01-17 20:35:29
Jan 17, 2019 20:36:45.014 [2148] VERBOSE - * Taking directory ‘MASH Episodes’ (1730) out of the map (0 left)
Jan 17, 2019 20:36:45.014 [2148] DEBUG - Adding subdirectory for scanner: “C:\Users\bill\Desktop\TVSHOWS\MASH Episodes\Season-10”
Jan 17, 2019 20:36:45.025 [2148] DEBUG - * Scanning directory C:\Users\bill\Desktop\TVSHOWS\MASH Episodes\Season-10 (parent: yes)
Jan 17, 2019 20:36:45.038 [2148] VERBOSE - * Noting that ‘MASH Episodes\Season-10’ was updated at 2019-01-17 20:35:29
Jan 17, 2019 20:36:45.038 [2148] VERBOSE - * Taking directory ‘MASH Episodes/Season-10’ (1731) out of the map (0 left)
Jan 17, 2019 20:36:45.039 [2148] DEBUG - Adding file for scanner: “C:\Users\bill\Desktop\TVSHOWS\MASH Episodes\Season-10\MASH_S1001.mp4”
Jan 17, 2019 20:36:45.042 [2148] DEBUG - Directory had 1 files, database had 0 files, can’t skip.
Jan 17, 2019 20:36:45.081 [2148] DEBUG - Removing 0 media items that were left.
Jan 17, 2019 20:36:45.081 [2148] DEBUG - Removing 0 directories that were left.
Jan 17, 2019 20:36:45.081 [2148] DEBUG - Updating directory ‘’ (ID 1729) to time 2019-01-17 20:35:29.
Jan 17, 2019 20:36:45.093 [2148] DEBUG - Updating directory ‘MASH Episodes’ (ID 1730) to time 2019-01-17 20:35:29.
Jan 17, 2019 20:36:45.104 [2148] DEBUG - Updating directory ‘MASH Episodes\Season-10’ (ID 1731) to time 2019-01-17 20:35:29.
Jan 17, 2019 20:36:45.128 [2148] DEBUG - Refreshing section 12 of type: 2
Jan 17, 2019 20:36:45.129 [2728] DEBUG - Refreshing 0 IDs.
I have optimized database and cleaned bundles all to no avail.
Can someone help please?
Thanks,
Bill
Oh I should mention I have deleted and added the “TV Shows” library multiple times also to no avail.
thanks,
Bill
Mystery solved for anyone interested.
So I moved my entire PMS server from a windows server to an Unbuntu 18.04 sever with an NFS mount and rebuilt the entire library database from scratch and still had the problem of not picking up the new library items.
What it turned out to be is an inability to recognize the new season episodes with the naming convention I had been using for the previous nine seasons.
Seasons naming convention:
MASH_Ssee.mp4
  • Where ss = one or two digit season (e.g. 1 2 3, 4, 5, 6, 7, 8, 9, 10, 11)
  • where ee = two digit episode (e.g. 01 02 03 04 05… etc)
So MASH Season 9 episode 13 would be: MASH_S913
this worked great and was and is picked up by PMS.
However MASH Season 10 episode 5 would be: MASH_S1005
this is NOT picked up by PMS.
I changed file names to MASH_S10e05… voila! Tre Magnifque!
Probably some quirk in regular expression mapping coded into the PMS but really quirky to have to be so specific in naming.
It is not a quirk, it is simply the way computer programs sort numbers; not just Plex but all programs. 1, 10, 100 all come before 2, 3 etc.
Your solution was the proper way to build a file name to eliminate the sorting problem. Plex alludes to it in the documentation, but does not elaborate on it.
Plex doesn’t “allude” to the proper naming format, they spell it out.
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
Series/Episode type TV Shows
To name series/episode based shows:
  • TV Shows/ShowName/Season XX/ShowName – sXXeYY – Optional_Info.ext
Where:
  • XX is the season number
  • YY is the episode number
Optional_Info is additional optional text (e.g. episode title) that is ignored by Plex, and ext is the file extension. (Some operating systems such as Windows may hide your file extensions by default.)
I stand corrected, indeed they do for the episodes in a season. I was thinking of how to name the seasons in the folder structure.
Is it Season 01 or Season 1. For what does it do when you reach Season 10, 11, etc.?
Again, it’s pretty clearly spelled out. You want to use XX (e…g 01, 02, …, 10, 11, etc).
