Libraries not updating on Debian 10
Server Version#: 1.24.3.5033
Player Version#: 1.24.3.5033
Hi , I have an issue with plex media server since few weeks , basically it ignores most of the shows in the library. tried to reinstall the server. didn’t work. move the files to another folder, same issue , only 3 shows are "showing " (bad dum tsss)
do you have any idea on what’s happening
ps : during the scan i can see other shows that aren’t diplaying in the metadata part
thanks all for your support
Restart the server
Let it sit idle for 3 minutes
Download the logs ZIP file
Attach it here.
In the future, if you need to send privately – I will send you a PM – because partial logs aren’t of use.
ok sorry,
the scanner seems to find them tho.
is there a way to force add some files to show up
