I have a number of multi lecture courses produced by “The great Courses”. Can I make a separate library for them? If so how do I organise folders and are there special naming conventions?
Thanks. If I read you correctly I could use the TV library format with a library name of say “great courses” and then set up the file structure using the TV season/episode conventions. This should then let me have a library called great courses in which I could see individual courses as I would TV shows. I could then open a particular course and see the individual lectures. Meta data is not that important
