Library maintenance options
Server Version#: 1.18.0.1846
Player Version#: Plex-Web Version 4.8.3
In previous versions we were able to select a drop down from the library list to perform actions on the entire library such as “Clean Bundles, Empty Trash, Optimize database” etc. It seems like “Empty Trash” has now been moved to the individual library sections and the rest to “Troubleshooting”. Would it be possible to add a global “Empty Trash” option to the “Troubleshooting” section as well so we don’t have to go into every library section and delete its trash manually ?
https://forums.plex.tv/t/is-this-supposed-to-be-an-improvement/415582/21
with uno, you must click the ‘more’ link to show all servers/libraries, then on the server there should be a menu for maintenance items.
yes it still sucks, but better than having the menus scattered all over.
When I click on More at the bottom of the list on the left hand panel, and then it shows my server name. Then I can click on more actions and then manage server and there are options for Empty Trash, Optimize Database and Clean Bundles. I am also running Web Version 4.8.3
Thanks for pointing that out.
