Library Pin
Hopefully, I am not missing it but I am looking for the option to turn on a Pin (password) for selected libraries. I tried the idea to create another account and I found I could use a pin to password protect access to the library but it does not password protect the same library under the main login. Seems like if you turn on Pin protection you could optionally use that option.
Please enable Pin\Password option for any created library.
Is there the capability to Pin\Password protect a created library under your main login? I created a second account and that login can be pin\password protected but it leaves the main login exposed for anyone in the house to browse. That does not make sense why an option is not available to turn on pin\password protect a Library?
Did I miss it and can it be added? Thanks
You can PIN protect an account, not a library.
Apply a PIN to the server owner / admin account to keep someone from switching to it.
Using Plex Web, login as the server owner, go to Plex Home, mouse over account name, click on Set PIN.
Thanks for the suggestion. I was hoping we could do it at the library level but this will work for now.
