Library poster size slider not working
Server Version#:1.15.6.1079
Player Version#:3.100.1
In the Home, Movies and TV tabs, the slider to adjust size of posters is not working as intended
The 3 first presets on the slider don’t change poster sizes at all, only the last one will make them larger and sliding it back to any of the first 3 will make all have the same size as each other.
It is working here, although the very first hub ‘Continue Watching’ only shows 2 different sizes.
But the other hubs below are adapting to every size. (Although it can take 1 or 2 seconds until the change happens)
What is your screen resolution and do you have the web app running in a maximized window?
For me the slider has been broken for some time. I believe the issue is related to zoom. I’m using chrome with a 1920x1080 resolution display and I have set the zoom to 90%.
Setting the zoom to anything other than 100% breaks the slider.
That may be correct. But why do you need it at 90%?
I actually use 90% zoom by default on my browser for all browsing. Have for years and hate fat chunky fonts - its really a personal preference.
Regardless, WebUI should work fine regardless of the zoom ratio if its developed to support such a standard browser feature.
