I have the server version v1.21.2.3918 and with the latest web client (v 4.50.1) I can no longer set the size of my posters. It looks like they default to the largest size.
Where?
In libraries? If so, which view mode?
Are you using a very high resolution screen?
Have you set a Zoom factor in your screen settings (at the operating system level)
Which web browser are you using?
Have you tried to disable web browser add-ins?
Have you compared the local and the hosted web apps?
It’s still working here, in either version of the app.
On every screen, home and libraries. This is on a 1440p widescreen monitor (Chrome v88).
Just made my window smaller and now it works, the slider increases and decreases the size.
But when I have it full screen, I cannot reduce the size of the posters, they are massive. Was it always like this?
I seem to remember it has to do with a limitation of one of the used Javascript libraries. It can only be solved when they do a version bump there. (which might not happen in the immediate future)
Good to know
