I would like to have a bandwidth limit option for uploading.
Whenever plex is uploading to someone or cloud sync my internet is unusable!
This is should be very easy to implement.
Cheers
Andrew
Sent from my iPhone using Tapatalk
Assuming you are on Windows check out netlimiter. It will allow you to restrict by process, source, destination, or anything else you might dream up. It also has a scheduler so you could allow fully bandwidth at night when you are sleeping.
There are several feature requests for this already. Search for "bandwidth" when in the feature request subforum and you will get a ton of hits. This one for example: https://forums.plex.tv/topic/96082-request-sharing-limitations/
Closing this one to get the number down at least one :)
