I have transcoding problem since 1.16.6.1592. That was the last working version. I tried 1.17 and now the latest 1.18 but the problem is the same.
So if I use the LG webOS client (which is transcodeing all the time as far as I know it is normal) the movies stop, client crashed, nothing in the logs.
I check the server side and the CPU is not really high, disk, memory is normal BUT the outgoing network bandwidth couldn’t go upper than 20MBit/s with 1.18 but it was higher than 60 with 1.16, and that was working.
Before 1.18.2 I could downgrade to 1.16.6.1592 with yum. But now there isn’t any other viersions on https://downloads.plex.tv/repo/rpm/$basearch/ but the latest.
Please put back the old version to the yum repo. I couldn’t use plex with TV anymore.
Thanks,
