Liv TV & DVR Channel Mappings
Looks like the channel mapping setup is a little broken and has been bugging me for a while!
So if there is two channels ie 106 and 0106 which will be 106 in the EPG (thanks Sky for using silly numbers) it’ll default to the first one regardless of the selection as below.
So if I select 106 Sky Showcase, it’ll be Classical FM in the EPG. Anyone got any ideas how to fix or is this an issue plex need to fix?
Server Version#: 1.24.2
Tuner Make/Model: xTeVe
Guide/Lineup name: Sky Q
Using XMLTV?: No
Channel number/Name: 106 Sky Showcase/Sky One
