Live TV & DVR EPG CHANNELS selection box out of order
Server Version#: 1.24.0.4921
Tuner Make/Model: WinTV-quadHD
Guide/Lineup name: Custom
Using XMLTV?: Yes
Channel number/Name: All
When adding channel mappings after the initial setup pulling down the EPG CHANNELS selection box will display the options out of order. It should display in order from first channel number to last channel number. Instead it’s random. This used to work the correct way but now it doesn’t and hasn’t for months. Please put the selections in order so it doesn’t take an hour to add a few channels. Right now it’s easier to just delete the whole DVR and re-create it as the initial channel matching is faster than doing it manually.
