Live preview scrubbing
display a small thumbnail while seeking forward or back through your videos, making it much easier to find the exact scene you are looking for or when the commercial has ended
Are you referring to videos you recorded? If so, this feature is already there. These images need to be generated ahead of time, and can be done by PMS, just make sure you have the setting enabled. Then once these thumbnails are created, clients that support the feature will show a pop-up in the timeline.
Thank you, I was referring to videos that I recorded. I have found the appropriate check box in the settings, and it works,
