Live Tv - change channels Crash
Server Version#: 1.32.5.7349
Tuner Make/Model: hdhomerun, xteve
Guide/Lineup name:
Using XMLTV?:
Plex Media Server Logs_2023-09-02_15-55-53.zip (473,1 Ko)
Channel number/Name:
Good morning,
I have been using Plex for several years for (Live TV) with an HD HomeRun and Xteve.
since the last year, I have a lot of difficulty with the change of channels which only crashes the section
from (Live TV)
I am able to repeat the mistake. I change channels 4 or 5 times and it starts. the session is started on the server but nothing on the client and gives an error code: 5000 request expired on the client. all customers give this message. ios, roku, android, web.
I went up on several different platforms the solution and still the same problem.
I mounted the Plex server on Docker Unraid, just the live TV section with HdHomeRun and Xteve
I mounted the Plex server on Unraid in vms with different OS, Windows, Ubuntu, just the live TV section with HdHomeRun and Xteve
I mounted on a physical PC with Ubuntu OS, just the live TV section with HdHomeRun and Xteve
I still have the same problem, if I change channels four or five times in a row, the LiveTv section of the plex no longer works. In the Dashboard, several Live TV-Sessions are present and at this moment it is inaccessible. you have to restart the Plex server to make the LiveTV section work again.
I attach the log file.
Ubuntu 22.04.3
plex version 1.32.5.7349
Is it possible to get feedback please.
I have this every day
Thank you so much
Do not change the channel while another channel change is in progress. Let the channel either 1) load or 2) error out before trying to change the channel again.
even if I wait, 24 hours, if I change channels, it adds up in the series of recording sessions. in command line, I see nothing that I can kill to stop. the only way is to reboot.
Hello,
After about one hour of listening on the live tv, I return to the schedule guide and the inital problem continues. If I choose another channel, the recording sessions this multiplies and impossible to tune the string. I attach another log
Plex Media Server Logs_2023-10-05_20-14-52.zip (7,5 Mo)
