I have gone through a few of these Hauppauge WinTV-dualHD devices, they seem to overheat, can some recommend a decent device for Live TV, I’m in New Zealand and have a UHF ariel (Freeview)
Hi @claynz give this site a go https://shop.silicondust.com/shop/product-category/dvb/ as the HDHomeRun are great.
Thanks, just what I’m after!
I highly recommend Silicon Dust Tuners, very easy to install and simple interface. You can’t go wrong.
Cheers
Thanks, I’ve ordered the DVB-T/T2/C HDHomeRun FLEX QUATRO Refurbished (HDFX-4DT-R)
Having issues with the Live TV Guide loading on the app yet works fine on the web version. any ideas, thanks
I highly recommend this XMLTV guide for Plex in New Zealand https://nzxmltv.com/
I use https://nzxmltv.github.io/xmltv/guide.xml
It works fine for me, but I read somewhere it is all going to change soon
Apple TV is working ok, it seems to happen when I play from the What’s On Now and Shows On Now
