Live TV & DVR gone from AppleTV, available on all other devices
Server Version#: 4.77.2
Player Version#: 7.29.1 (2058)
Live TV & DVR just disappeared from the navigation. Still have access on the server, laptop, iPhone, etc., with full signal strength.
You probably need to pin the “Live TV” section to your sidebar. Live TV & DVR was merged into this.
Good luck,
Chris
Nope. It’s nowhere. All my server libraries are there, including the ones I don’t have pinned to the Home Screen, but no Live TV & DVR option.
There is no such thing as Live TV & DVR anymore. It is now called Live TV and if it’s not pinned on the sidebar then it’s under “More”. Don’t forget to set your guide sources otherwise they may not be showing.
Ah, okay. That did it. I had to restore defaults and add it. The fact that they list it in the initial setup as “Live TV on Plex” was misleading, I thought that would be all the streaming channels they offer, and not my locals from the antenna. Thanks!
Everything is merged into one place now but it all still works the same with the addition of Favorites.
