Missing Live TV and DVR on Shield
My Live TV and DVR option disappears from my menu. It should be there but when I move down all the list of options, it is not there to be selectable. How do I go about figuring out why? I also have a Roku hooked up and it sees it. It is also there on Plex Web on my Windows laptop.
If you scroll down all the way on the left sidebar navigation menu until you get to “more“, and click on that then scroll to the server that has live TV/DVR installed, do you find it there? If so, then you can pin it to your main navigation menu again.
I have tried that. If I scroll down to “more”, then click on my Plex server, it goes from TV Shows to the Plex drop down.
I just restarted the plex server and it has reappeared.
