Live TV & DVR with HDHomeRun dropping
Server Version#: 4.67.0
After 10-15 min, about, Plex will drop the Live TV connection. Recordings do not have this issue. Basically, the TV station selected will play and then a spinning wheel will occur where eventually it will time out. The logs will show this, although not sure if this helps or not? See image. The HDHomeRun app has no issues.
Same issue here using the Hauppauge adapter, I was hopeful that the last update would fix this but it seems we were out of luck
What are you using to view the stream? Or does it not matter? I am using an ONN device.
Note the time: 3 minutes after the hour.
If you go over to the Live TV forum, lots of people are having issues with Live TV failing roughly 3 minutes after the start of every scheduled program in the EPG.
