Live TV Guide for Android TV - Navigation Assistance needed
Server Version#: 4.147.1
Player Version#: 10.30.4.4092
Tuner Make/Model: HDHomeRun FLEX 4k
I’m struggling to make sense of how to navigate the Live TV guide on my Android TV devices here. For example, on the web, if I want to look at tomorrow, I can just go to where it syasy Today and change that to whatever day in the future I want. On Android, I can’t seem to duplicate that function. If I try scrolling to the right continuously to try and get there manually, this also doesn’t work as it finally just stops scrolling after it gets to 24 hours, then the arrow buttons on the remote do NOTHING. I have to hit back to get out of whatever invisible thing it went to.
At this point, I find it hard to believe they just left this so broken. It makes me feel like I must be missing something. Even after a good 30 minutes of searching, I came up empty. That’s when I decided I will just reach out to support for the product I pay for only to discover the big middle finger from them only offering billing support. Ahh. I see now. Not happy about that, especially after using it for years with no issues…I am now reconsidering my software choice, knowing there are definite alternatives out there.
But, I digress. Any pointers on using the guide on my Android TV devices and making this experience a bit better? Maybe an obscure plugin? Any help would be appreciated.
…..and yes, as I suspected, this guide is S**T and Plex doesn’t give a damn. The silence speaks volumes. I’m off to find another product. Thanks for all the great help, Plex.
Depends on the device. You are on the “Legacy” version of the app, the “New Experience” available for Android Mobile allows you to tap on the today and change it.
I guess I should have been more clear. This is on Android TV devices. Which is ironic, considering it’s on a an actual TV (like yeah, I still use those things). Post updated.
Tick Tock, and not a F**king thing. Yep. Jellyfin is rocking over here; FYI. If you did this by design, SUCCESS!!! You made me find a new FREE product that works better than your corporate BS!
Bueller? Bueller? Bueller?
Bueller?
That is the legacy Android Client where it isn’t likely to change. When the “New Experience” finally makes it there it is working to change the day.
Wow, Thanks! Finally some news. If this is real, glad to hear it.
