LiveTV Guide not moving with time
Server Version#:
Player Version#: 9.19.0.177
Tuner Make/Model: Sony Bravia. Android TV
Guide/Lineup name: Plex Movie Channel
Using XMLTV?: No
This has been a problem for long time now.
When 1st selecting live tv, the guide looks fine. If you watch a show for an hour or something and hit “back” to see the guide again, it doesn’t move “forward” (for lack of the better word). Thus the guide is fragmented and pretty much requires you to go to the left hand nav, select something other than livetv, then select livetv again, then the guide will look “normal”.
I’ve attached a screenshot of what happens when you watch a plex channel (in this case, the movie one) for an hour and then hit the back button to view the guide. You can see the left side of the guide doesn’t “line up”.
I haven’t noticed this behavior on other devices but I only have 2 android tv devices and only use 1 on a regular basis.
I’m not sure this is even going to be looked at but I thought I would report it. I can provide logs etc… if desired.
If it’s a simple config change or something, I would appreciate any suggestions.
Release notes in the beta say that it is fixed, should show up in the regular release soon.
