LIVE TV HDHOMERUN No Show On iPhone
Live TV or Guide do not appear on my iPhone 6 Plus Plex app. I can see it on the laptop or desktop PC.
Version 1.5.5.3634 - Check for Updates - Up to date
PMS says it’s up to date but I heard on the Forum that there’s a newer version.
update your server. you need at least 1.7.2. https://www.plex.tv/downloads
to be clear. 1.7.2 is a Plex Pass only version. for the the “check for updates” function to tell you about those versions, you need to decide to change the update channel to Plex Pass in Settings>General. or wait till the next public release
That update channel was real helpful. It was set to public. Thanks
