Server Version#: 1.32.6.7557 (Linux Debian)
Player Version#: 4.108.0
Tuner Make/Model: Vbox TV XTi-3442
Guide/Lineup name:
Using XMLTV?: Yes
Channel number/Name: All
Using Plex web, channel is buffering then freezing every 5 seconds.
Guide/Lineup name:
Using XMLTV?: Yes
The problem remains after last core update : 1.32.8.7639
I am not a DVR guy.
Need to know info about your CPU. What are you running ? Container? VM?
Which OS distro & version ?
CPU is : Intel(R) Core™ i5-8500T CPU @ 2.10GHz
Container / VM: No
OS : Debian 10 Buster
You need to update that.
Buster (Debian 10) went EOL August 2022
Would that help ?
That’s one part but, before taking that step, I really do need to see your server DEBUG log files which capture this happening.
From there, I’ll know.
The best logs for me are:
Attach the logs ZIP file it gives you here with your next reply.
Attaching plex media server log (removed)
I need the ZIP.
I asked for it because of what you showed me in the log.
The info I need is in the previous rollover logs.
Please grab the ZIP file and attach it.
I’ll delete it after downloading if you wish
OK I understand. Attaching zip.
Yes, please.
Why did you prune out all the rollover logs ?
Also, You have DEBUG logging disabled. I can’t do anything with “WARN” only messages.
excerpt
Dec 05, 2023 22:13:13.723 [140259323476792] WARN - [Req#4e1/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.728 [140259366976312] WARN - [Req#4e4/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.731 [140259401284408] WARN - [Req#4e7/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.732 [140259364866872] WARN - [Req#4ea/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.733 [140259394767672] WARN - [Req#4ed/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.735 [140259323476792] WARN - [Req#4f3/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.736 [140259401284408] WARN - [Req#4f4/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.737 [140259364866872] WARN - [Req#4f8/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.738 [140259394767672] WARN - [Req#4fb/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.739 [140259366976312] WARN - [Req#4fe/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.743 [140259323476792] WARN - [Req#501/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.747 [140259401284408] WARN - [Req#504/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.748 [140259364866872] WARN - [Req#507/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.749 [140259394767672] WARN - [Req#50a/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.750 [140259366976312] WARN - [Req#50d/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.751 [140259323476792] WARN - [Req#510/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.752 [140259401284408] WARN - [Req#513/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.753 [140259364866872] WARN - [Req#516/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.754 [140259394767672] WARN - [Req#519/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
Dec 05, 2023 22:13:13.756 [140259323476792] WARN - [Req#51f/Live/c301c9ad-e099-40b6-ae2d-5dbeb40bf5c5] Failed to find consumer
please re-enable DEBUG and recapture.
I’ll delete again after downloading.
I have the same problem. Live TV is not usable. Shows in DVR recording fine though. Just streaming live not working.
CentOS 9 Stream. Been running 1+ years without issues.
Have to go back 2 revs in plex server to fix the problem.
May I PLEASE have somebody’s DEBUG server logs which capture this?
I don’t have DVR capability so can’t replicate.
I’ll immediately write it up and submit
Unfortunately, I don’t have any logs for 7639 since I rolled back to 7557. Did I think I did figure out why live TV kept freezing. Version 7639 was causing my NUC to overheat and throttle.
@ChuckPa Please excuse my late reply. Attached zip with log files with DEBUG enable.
Plex Media Server Logs_2023-12-10_19-38-24.zip (30.2 KB)
I had a similar issue. I would put on specific channels and every 5 seconds it would freeze, then play. I was running this on an old AMD 8-core processor. I gutted that box and replaced with a dual Xeon processor board. Now that problem does not exist.
So I would look at your processing power. I hope this helps.
Problems remains with Plex Server version : 1.40.0.7998
@Brad_S It’s working fine on iOS or on desktop. Only web plex is not working
