Hi, may i ask when using chrome for example, why is live tv always transcoded and costs cpu usage
example, same channel, same stream
when playing live i see high cpu usage and when checking i see video is also transcoded (x264 to x264)
when playing a record i see only audio transcoded (as supposed), so codec should be fine,
transcoder in DVR is set to ORIGINAL (should affect records anyway only), also player settings is set to auto,
homestreaming also …
and whatever i change there it doesnt really matter cause LiveTV is always getting transcoded.
also there is no option when playing back live TV to adjust the quality in player, on records or files i can adjust from
original down to … when playing Live theres nothing to set …
doesnt matter if its an 720p or 1080i stream (progressive vs. interlaced), same behavior …
nvm if im in LAN (wired or wireless) or externally …
my LAN is setted up on 10GB, playing multiplay UHD streams at a time aint a problem, so bandwith shouldnt be an issue
WLAN is from N, AC, AD … so also enough … also playing from kodi and tvheadend all streams play fine, just to clear
there is no bandwith issue … same server mashine, same clients.
externally im on 400/25, so 25mb upstream, which even would be enough for almost all LiveTV broadcasts too …
am i missing some settings somewhere ?
for an tip thanks ahead
