Live TV wont play on any device
I had Live TV working great with my HDHomeRun for months but in the last week or so it has stopped working.
When I tap on a show in the program guide (iOS for example) the show opens and it attempts to start playing… The circle spins for a bit and then it drops back to the show page with the play button.
If I check the Plex Tuner Service.log, I see the following about drv_file.ini not existing… not sure if thats related…
    Aug 11, 2017 23:24:29.274 [3028] INFO - * web_service_t::process_device_discovery
    Aug 11, 2017 23:24:29.275 [3028] INFO - * device_reactor_t::get_device_list ()
    Aug 11, 2017 23:24:29.275 [3028] INFO - * dvb_device_factory_t::get_device_list ()
    Aug 11, 2017 23:24:31.291 [3028] INFO - * SAT2IP - discover_satip_servers(): no servers found
    Aug 11, 2017 23:24:31.713 [10016] WARN - [E] enum_create(): Class not found, CreateClassEnumerator returned S_FALSE
    Aug 11, 2017 23:24:31.714 [10016] INFO - * DeviceGetListEx_impl: pDL->Count:0
    Aug 11, 2017 23:24:31.715 [3028] DEBUG - * file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
also this snippet from the Plex Media Server.log where it appears to start and then terminate the stream first mysteriously and the second time with “Client Stopped Playback” which I didnt do.
Aug 11, 2017 23:40:09.914 [5448] DEBUG - Request: [192.168.1.81:56642 (Subnet)] GET /video/:/transcode/universal/stop?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&location=lan&maxVideoBitrate=20000&partIndex=0&path=%2Flivetv%2Fsessions%2F424d72fb-007d-460f-8209-78ae6b60c959&protocol=hls&session=BD0418C9-7463-490C-B3CA-404A21FD60CA&subtitleSize=100&videoBitrate=20000&videoQuality=100&videoResolution=3840x2160 (13 live) TLS GZIP Signed-in Token (sl4ppy)
Aug 11, 2017 23:40:09.915 [10316] DEBUG - Downloading document https://plex.tv/updater/products/1/check.xml?build=windows-i386&channel=8&distribution=english&version=1.8.1.4140-82ea538ca
Aug 11, 2017 23:40:09.915 [10316] DEBUG - HTTP requesting GET https://plex.tv/updater/products/1/check.xml?build=windows-i386&channel=8&distribution=english&version=1.8.1.4140-82ea538ca
Aug 11, 2017 23:40:09.919 [0224] DEBUG - [Now] Device is iOS (<username redacted>).
Aug 11, 2017 23:40:09.921 [6904] DEBUG - Found session GUID of BD0418C9-7463-490C-B3CA-404A21FD60CA in session start.
Aug 11, 2017 23:40:09.921 [6904] WARN - Got a request to stop a transcode session without a session GUID (or with an invalid one).
Aug 11, 2017 23:40:09.922 [2816] DEBUG - Completed: [192.168.1.81:56640] 200 GET /library/sections (13 live) TLS GZIP 22ms 842 bytes (pipelined: 6)
Aug 11, 2017 23:40:09.924 [0224] DEBUG - [Now] Profile is iOS
Aug 11, 2017 23:40:09.924 [0224] DEBUG - [Now] Updated play state for /livetv/sessions/424d72fb-007d-460f-8209-78ae6b60c959.
Aug 11, 2017 23:40:09.925 [0224] DEBUG - Streaming Resource: Terminating session 0844C078:660E1B9B-C8DB-4D05-A674-B6C7E10A2566 which is using transcoder slot.  Used slots is now 0
Aug 11, 2017 23:40:09.926 [0224] DEBUG - Streaming Resource: Terminated session 0844C078:660E1B9B-C8DB-4D05-A674-B6C7E10A2566 with reason Client stopped playback.
Aug 11, 2017 23:40:09.926 [0224] DEBUG - Streaming Resource: Removing session 0844C078:660E1B9B-C8DB-4D05-A674-B6C7E10A2566
Aug 11, 2017 23:40:09.927 [9920] DEBUG - Completed: [192.168.1.81:56642] 200 GET /video/:/transcode/universal/stop?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&location=lan&maxVideoBitrate=20000&partIndex=0&path=%2Flivetv%2Fsessions%2F424d72fb-007d-460f-8209-78ae6b60c959&protocol=hls&session=BD0418C9-7463-490C-B3CA-404A21FD60CA&subtitleSize=100&videoBitrate=20000&videoQuality=100&videoResolution=3840x2160 (13 live) TLS GZIP 14ms 195 bytes (pipelined: 5)
Aug 11, 2017 23:40:09.933 [2816] DEBUG - Completed: [192.168.1.81:56643] 200 GET /:/timeline?bufferedTime=0&duration=1800000&key=%2Flivetv%2Fsessions%2F424d72fb-007d-460f-8209-78ae6b60c959&location=lan&ratingKey=com.gracenote.onconnect%3A%2F%2Fepisode%2FEP014284731316&state=stopped&time=0 (13 live) TLS GZIP 33ms 470 bytes (pipelined: 3)
I have deleted and re-added the tuner multiple time to no avail. Hope someone has a suggestion.
