LiveTV and subtitles
Are we supposed to be able to use subtitles when using livetv?
Quite some streams have DVB subtitles available and some teletext subtitles.
I cannot choose any subtitle in these cases.
One stream out of maybe 10 started to transcode due to dvb subtitle. But most streams doesn’t show anything.
They all work if I start the streams in VLC or Kodi or iptv extreme so they do work.
I have also noticed some streams where aspect ratio is totally wrong.
Never happen in above clients.
Something I can do or is this expected behaviour?
I am using IPTV and have tried Xteve and tvhProxy (with tvheadend). Doesn’t matter how I feed the streams to plex, alway the same problem.
TV part of Plex doesn’t seem so polished. At least not now.
While this was publicly not supported by Plex, recently I see subtitles available while I am watching live TV. They seem to work pretty good too. I am in the US though, not sure if it is different overseas (I say this because you mention DVB and Teletext).
FYI
Which subtitle format are used in US (for livetv)?
