LiveTV stopped working after 1.16.5.1554
LiveTV stopped working after 1.16.5.1554 with the following error:
“Could not tune channel. Please check your tuner or antenna.”
I’m using xteve to pass the IPTV info to plex. I am able to play the url xteve is passing to plex in VLC without issue. Also, If I roll back to 1.16.5.1554 from a newer version it works fine again.
Here is the console output:
Nov 19, 2019 19:21:22.949 [31732] Error — Unable to find title for item of type 5
Nov 19, 2019 19:21:22.950 [31732] Error — Unable to find title for item of type 5
Nov 19, 2019 19:21:23.263 [33736] Error — [Transcoder] http://192.168.0.143:34400/stream/e4f09acae38570c82aca7daca4a798af: Server returned 404 Not Found
Nov 19, 2019 19:21:23.275 [31732] Error — Failed to start session.
Nov 19, 2019 19:21:23.275 [31732] Error — Recorder: Unable to create transcode session or session failed to start.
Nov 19, 2019 19:21:23.276 [31732] Error — Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Nov 19, 2019 19:21:23.279 [31732] Error — Grabber: Starting media grab failed.
Nov 19, 2019 19:21:23.279 [31732] Error — Unknown metadata type:
Nov 19, 2019 19:21:23.281 [31860] Error — Subscription: Rolling media grab failed to start.
I would think this is the issue:
As this is not the same url passed from xteve
Any help would me much appreciated as I would like to keep the plex server on an updated version.
Finally fixed the issue and I am now able to upgrade to the latest version and LiveTV works. To correct the “could not tune channel” message. I needed to enable the buffer in xteve settings and set to use xteve (you can set it to xteve, VLC or FFmpeg for the buffer) This feature is only available in xteve 2.0 and later.
