Loading PMS on QNAP TS453A
Server Version#: 4.91.1
Player Version#:??
I am trying to add PMS to my NAS, which package do I use for the download?
Any issues related to that subject line?
@rbowen6585
QNAP App Center now has an updated package entry for PMS 1.28.0
Use the version it suggests. It will give you the correct one for your machine.
(64 bit intel)
When you want to update from Plex, you want the QTS 4.3 and above - Intel 64 bit download package for Manual Install.
Thanks, it just seems as if I lost connectivity to my server and a reinstall seems necessary. I dont see any fix to reclaim my server unless you have a suggestion…
@rbowen6585
It just so happens, I do :sunglasses: :slight_smile:
