Local Assets being ignored, unable to match
Server Version#: 1.31.0.6654
Player Version#: Web -4.87.2
I have been having problems getting some TV Shows to show up properly in the library. These are not typical TV shows but rather sporting events and are date-based. Quite a while back I found a page explaining how to structure the folder hierarchy and name the files to get them to show up. I followed that guide back then and it worked great. I recently had to setup a new Plex server and move all my media to a new machine. Now when scanning, these shows have no information. For further explanation, I have football games saved on my drive as follows…
  • TV Shows/
    • NFL/
      • 2016/
        • NFL - 2016.11.16 - Packers @ Eagles - 720.mp4
I also have races saved as follows…
  • TV Shows/
    • NASCAR Sprint Cup Series/
      • theme.mp3
    • 2015/
In both shows, none of the local assets are discovered or applied when scanning the library. The posters are not applied nor visible as an option when manually editing. The background images are not applied and are not visible. And in the cases where I have a theme tune for the show it does not play that either (and yes player is set to play theme music for shows).
I know that the examples I gave are from dates long ago, but when I scanned the show at that time with the agent that was available then, it worked. I know there is a new Plex TV Series scanner in todays versions. Yes I checked to make sure the “use local assets” box was checked.
So, I tried to go under advanced options for the library and choose “Plex Series Scanner” which allowed the problematic sports shows to appear correctly in the library with all of the local assets applied, but then all the other shows lost their information (I read later that this may have been a separate issue caused by the order of agents in the server settings and I have since reverted the ordering to default).
The shows are also now split into strange “seasons” based on recurring text in some titles (such as race lap length for the NASCAR series, example: “Season 125” or “Season 200”), where as it used to be grouped into “seasons” based on the year of the folder nested directly below the title (example: “Season 2015” or “Season 2016”)
To further frustrate the situation, after switching to the “Plex Series Scanner” and scanning the library, I was unable to return to using the “Plex TV Series” agent. Any time I attempted to revert back I was given a “Changes cannot be saved” error.
I ended up deleting the entire TV Shows library and adding it back, having it set to “Plex TV Series” agent. However after scanning the whole folder again, the problematic shows are having the same issue as I originally had.
I have a large library and do not want to keep deleting and adding and changing settings as it takes a long time to test and undo changes made while troubleshooting. Can anyone offer assistance on how to get local assets to appear with the new TV show scanner?
Cheers
