Server Version#: 4.62.1
Hi
I added a new TV shows but plex don`t recognize and old folders dissapared. If I added the same folder in Movies the files are working fine!!
I dont undestand…
The server is in synology with DSM 7 (in DSM 6 fail too)
I don’t think that’s that since files that appeared before have disappeared and the new files are new seasons, that is, for example, season 1 if it appears in series and season 2 does not appear
Mind sharing an example of your file structure / naming?
Also… what exact scanner/agent are you using for this library (see ⋮ > Manage Library > Edit... → Advanced)?
Could be you got lucky in the past and some change is now causing this trouble.
For example: “La casa de papel” → Temporada 1 → File1, File2,…
—> Temporada 2 → File1, File2,…
Also… what exact scanner/agent are you using for this library (see ⋮ > Manage Library > Edit... → Advanced )?
scanner : Plex Series Scanner
Agent: TheDVDB
It appears you indeed got lucky in the past.
Try to name your files in accordance with the schema required by Plex.
TV Shows <- the folder linked to your tv-show library
La casa de papel
Season 01 <- use the English name for "tempoada"
La casa de papel - s01e01.ext
La casa de papel - s01e02 - Imprudencias letales.ext <- episode name is optional
La casa de papel - s01e15.ext
Season 02
La casa de papel - s02e01.ext
Where .ext is a placeholder for your file extension.
Side note: at some point you might want to consider upgrading your library to the new Plex Series scanner/agent.
