Local server limited to remote quality?
Plex Media Server Logs_2019-03-08_13-15-14.zip (6.7 MB)
here are the server logs after a fresh reboot and no scans being done. the server is back to transcoding everything again. nothing has changed settings wise just a few server reboots. no updates to server OS or changes to router settings. hope you can figure out whats causing it because i have no idea
thank you for your help
I am looking at this playback event,
Mar 08, 2019 13:14:44.599 [0x7fe671ffb700] DEBUG - Auth: authenticated user 1 as high_bounce
Mar 08, 2019 13:14:44.603 [0x7fe671ffb700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Mar 08, 2019 13:14:44.603 [0x7fe671ffb700] DEBUG - Selecting best audio stream for part ID 18327 (autoselect: 1 language: en)
Mar 08, 2019 13:14:44.603 [0x7fe671ffb700] DEBUG - We're going to try to auto-select a subtitle.
Mar 08, 2019 13:14:44.603 [0x7fe671ffb700] DEBUG - Audio Stream: 55990, Subtitle Stream: -1
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: Selected protocol http; container: mkv
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: analyzing media item 18322
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: Direct Play is disabled
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: no direct play video profile exists for http/mkv/h264
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: no direct play video profile exists for http/mkv/h264/aac
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - MDE: Supernatural - S14 E14 - Ouroboros: selected media 0 / 18322
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - Streaming Resource: Required bandwidth unknown (media requires deep analysis) Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
Mar 08, 2019 13:14:44.604 [0x7fe671ffb700] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - Scaled up video bitrate to 12000Kbps based on 1.500000x fudge factor.
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41, disable video DS as 2147483647kbps is > the 1724kbps available, disable audio DS as 2147483647kbps is > the 162kbps available
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - Scaled maximum bitrate for resolution reduction to 1691Kbps.
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: Selected protocol http; container: mkv
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: analyzing media item 18322
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: Direct Play is disabled
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: no direct play video profile exists for http/mkv/h264
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: no direct play video profile exists for http/mkv/h264/aac
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - Ouroboros - video.width limitation applies: 1920 > 720
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: Direct Streaming is disabled, so video stream will be transcoded
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: no remuxable profile found, so video stream will be transcoded
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: E14 - Ouroboros: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Mar 08, 2019 13:14:44.605 [0x7fe671ffb700] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Mar 08, 2019 13:14:44.606 [0x7fe671ffb700] DEBUG - MDE: Supernatural - S14 E14 - Ouroboros: selected media 0 / 18322
Mar 08, 2019 13:14:44.606 [0x7fe671ffb700] DEBUG - Streaming Resource: Adding session 0x7fe6541bc330:rj153b0sui5m2w7g8wi639pb which is using transcoder slot.  Used slots is now 1
Mar 08, 2019 13:14:44.606 [0x7fe671ffb700] DEBUG - Streaming Resource: Added session 0x7fe6541bc330:rj153b0sui5m2w7g8wi639pb
Mar 08, 2019 13:14:44.606 [0x7fe671ffb700] DEBUG - Streaming Resource: Reached Decision id=11796 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=18322 part=(id=18327 decision=transcode container=mkv protocol=http streams=(Video=(id=55988 decision=transcode bitrate=1691 encoder=libx264 width=720 height=406) Audio=(id=55990 decision=transcode bitrate=162 encoder=libopus channels=2 rate=48000))))
Mar 08, 2019 13:14:44.607 [0x7fe6acbc3700] DEBUG - Completed: [192.168.1.24:56829] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F11796&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=2000&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&session=s5kz6xsxql0ol0e6lby44pld&subtitles=auto&copyts=1&Accept-Language=en (10 live) TLS GZIP 8ms 1266 bytes (pipelined: 4)
Mar 08, 2019 13:14:44.662 [0x7fe6ad3c4700] DEBUG - Auth: authenticated user 1 as high_bounce
Mar 08, 2019 13:14:44.662 [0x7fe6727fc700] DEBUG - Request: [192.168.1.24:56836 (Subnet)] GET /video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F11796&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=2000&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&session=s5kz6xsxql0ol0e6lby44pld&subtitles=auto&copyts=1&Accept-Language=en (11 live) TLS Signed-in Token (high_bounce)
Mar 08, 2019 13:14:44.662 [0x7fe6727fc700] DEBUG - Found session GUID of s5kz6xsxql0ol0e6lby44pld in session start.
Mar 08, 2019 13:14:44.662 [0x7fe6727fc700] DEBUG - TranscodeUniversalRequest: using augmented profile Konvergo
Mar 08, 2019 13:14:44.662 [0x7fe6727fc700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/11796?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video;videoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A2160%26level%3A52%7D;audioDecoders%3Dmp3%2Caac%2Cdts%7Bbitrate%3A800000%26channels%3A2%7D%2Cac3%7Bbitrate%3A800000%26channels%3A2%7D&X-Plex-Session-Identifier=rj153b0sui5m2w7g8wi639pb
Mar 08, 2019 13:14:44.663 [0x7fe6727fc700] DEBUG - Auth: authenticated user 1 as high_bounce
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - Selecting best audio stream for part ID 18327 (autoselect: 1 language: en)
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - We're going to try to auto-select a subtitle.
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - Audio Stream: 55990, Subtitle Stream: -1
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - Cleaning directory for session s5kz6xsxql0ol0e6lby44pld ()
Mar 08, 2019 13:14:44.667 [0x7fe6727fc700] DEBUG - Starting a transcode session s5kz6xsxql0ol0e6lby44pld at offset -1.0 (state=3)
Mar 08, 2019 13:14:44.668 [0x7fe6727fc700] DEBUG - [Universal] Using local file path instead of URL: /shows/raid/Supernatural/Season 14/Supernatural - S14E14 - 1080p.mkv
Mar 08, 2019 13:14:44.668 [0x7fe6727fc700] DEBUG - TPU: hardware transcoding: zero-copy support not present
Mar 08, 2019 13:14:44.669 [0x7fe6727fc700] DEBUG - Job running: EAE_ROOT='/tmp/pms-5cb03711-603b-420f-a922-e0b2293f18e7/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/a22632d-2034-linux-x86_64/' XDG_CACHE_HOME='/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/usr/lib/plexmediaserver/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'aac' '-probesize' '10000000' '-i' '/shows/raid/Supernatural/Season 14/Supernatural - S14E14 - 1080p.mkv' '-filter_complex' '[0:0]scale=w=720:h=406[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':osr=48000[2]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '21' '-maxrate:0' '1691k' '-bufsize:0' '3382k' '-r:0' '23.974' '-preset:0' 'veryfast' '-x264opts:0' 'subme=6:me_range=4:rc_lookahead=10:me=hex:8x8dct=1' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'libopus' '-b:1' '162k' '-f' 'segment' '-segment_format' 'matroska' '-segment_format_options' 'live=1' '-segment_time' '1' '-segment_header_filename' 'header' '-segment_start_number' '0' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/s5kz6xsxql0ol0e6lby44pld/f295af2c-396e-448d-a9c7-787bae07d7dc/seglist' '-segment_list_type' 'csv' '-segment_list_size' '2147483647' '-segment_list_separate_stream_times' '1' '-avoid_negative_ts' 'disabled' '-map_metadata:g' '-1' '-map_metadata:c' '-1' '-map_chapters' '-1' 'chunk-%05d' '-start_at_zero' '-copyts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/s5kz6xsxql0ol0e6lby44pld/f295af2c-396e-448d-a9c7-787bae07d7dc/progress'
Mar 08, 2019 13:14:44.669 [0x7fe6727fc700] DEBUG - Jobs: Starting child process with pid 6712
There are some limitations being applied.
  1. Video width: 1920 (source) > 720 (on the device) - Seems like an odd size but ok.
  2. Resultant video:
This is telling me that either a) the application or b) your local LAN configuration or topography is such that there is no “Direct” path on the same subnet.
Your networking shows the same subnet addressing 192.168.1.x which is consistent with a class C. What is the subnet mask? 255.255.255.0 or /24 which confirms as a class C
What about the player? What is its ethernet configuration ?
Lastly, again I ask… Firewall?
On the LAN, the required ports to detect Nearby status are:
https://support.plex.tv/articles/201543147-what-network-ports-do-i-need-to-allow-through-my-firewall/
Firewall is pfsense.
After that stream I rebooted again and got a direct stream. My network is all wired with a single Cisco switch. All on the 192.168.1.x addressing. I can send you the new logs if you would like? Seems to be weird intermediate issue now. Still getting the streams outside of the network with plex telling me it doesn’t have access to the internet.
