Just been testing out the new beta and straight away the first noticeable problem is the play pause function whilst using a Logitech Harmony remote. Previous versions the play/pause button worked fine and was interchangeable but now they only pause but won’t play. Im wondering if the button map has changed and if thats something that can be remapped on my end or if something can be fixed in the beta itself
Actually, it’s stopped working with my normal remote too!
Previously you could play/pause at any time with the play/pause button. Now, pause works fine, but play only works while the seek bar is shown on screen. As soon as it hides, you have to press select (tap the main button) to resume playing.
Can confirm that the issue occurs with the Siri Remote as well. Hopefully, this issue can be addressed in the next beta.
