Server Version#:1.21.3.4046
I have home videos installed in my synology NAS library with the Originally availablke date as yyyy-mm-dd. I would like to see this full date in a list view of videos but can only see year.
Is there a way of changing the view or meta data to a long date?
Gally
In list view you can add the Release Date column
Release date shows as an orange circle. I noticed a lock icon on the field so changed this to unlock but still no long date.
I did see this once but do not know what I have changed to block it.
can you show me a screenshot of what you mean by this. the only column afaik that ha s a circle is the Progress column which represents unwatched by the circle
I want to be able to see the Original date that I entered into the date field.
It ius this date I cannot see in a long format
OK. That looks like a bug with the columns in an “other videos” library. Thanks for reporting.
One other question.
When I click http://192.168.0.53:5000/web or the open button on the Plex icon the connection times out. When I use Plex.tv it uses and insecure connection.
I have no interest at the moment in external internet connections but do not understand if this is what should be expected.
If you are at home regardless of which URL you use then it is a local connection to your server. It is showing it is insecure because TLS encryption does not work in a local environment.
