Long Description Truncated when selected
Server Version#: 1.25.9.5721
Player Version#: 5.35.2 (Plex for Samsung Platform Version#4)
This is has been happening for a while now, so it’s just not related to the versions above. When I go into a Movie/TV Show it lists the:
Title, Year, Length, Genre, Rating, etc. (normal)
Then it gives the short description and if it’s more than three lines it’s truncated (normal)
However- when I move up to the short description and press enter on the remote to read the entire description it only gives one line (actually less than the short description!)
As I said, it’s been going on for at least 6 months. I’m not sure when it started, but it’s kind of annoying and just wanted to pop something into here to see if it can be fixed.
Thanks in advance!
