Long-time scan library
Server Version#: 1.29.1.6260
Hello, good afternoon
Recently i’ve migrated my server from one cloud-dedicated to another, everything was good, and i have all my stats, libraries and contents in same place.
Except he mount-point. Now it’s in /mnt/folder-mount-point. I had to edit in every movie or tv-series libraries the folder where my files are.
But, the the most numerous one, it’s taking looooooong time, almost a week, and and I still have left two music libraries and my personal photos.
…The server it’s a Xeon 1220V3 with 8 GB RAM DDR3 and 2 HDD 2 TB each. Linux based and Ubuntu 20LTS.
How can I find out why it takes so long?
Thanks in advance
Without some additional details its somewhat hard to tell what might be the issue but these are some things you should consider …
  1. What plex agent/scanner are you using ? Is it the new modern ones or the slower legacy ones.
  2. Does your media match the recommended plex naming, including placing movies inside their own folders to help with performance. Same for TV and Music, make sure to follow the guidelines.
  3. Do you have Prefer local metadata enabled on your libraries ? This can slow things down as plex needs to scan indepth each file for its embedded tags.
  4. Under settings / library do you have stuff like Generate video preview thumbnails enabled for when media is added. This goes for each of the high cpu intensive tasks in that section. I’d always recommend setting these to never until everything is added to my libraries and then I’d change them after the initial scanning / matching is complete.
hello, thanks again for reading:
  1. the agent are all the new ones
  2. the media matches 100% the naming convention. I’m very obssesed with it.
  3. i’m only using local art, if it’s present. not the metadata.
  4. and i have never used the thumbnail generation for video files
there are 160K files …nearly 4000 tv-shows :grimacing:
Okay, what about Generate intro video markers, Analyze audio tracks for loudness or Analyze audio tracks for sonic features ? These could also be a factor.
That’s fairly large, I’ve 675 shows with 30k episodes but I can still scan and match (from scratch) in approx 60-90 minutes but I do have a fast’ish machine and very fast internet connection. I’m surprised yours is that large as you state 2 HDD 2 TB each or that just your plex server and not the media ?
If plex itself is installed on spinning disks as opposed to an SSD then that could be a significant factor in the slow performance.
Hello again, :smile:
i’m not analizing for the skip intro, altought i’ll liked, it’s an insane job due the amount of files. that’s not the point.
in other hand, the music libraries are not planned to be scanned, will be the last ones … the feature for sonic analysis it’s done and saved in the previous server…i think
…and the whole plex it’s about 120 GB
…the machine it’s powerful enough to do the job in a 2 or 3 hours
at this point, erasing whole library and re-doing again, perhaps will be faster. rhe watched status are saved at trakt and pms itself
Please download the server logs (Settings - Server - Troubleshooting - Download Logs) and attach them here.
It will tell us what’s happening and avoid the guesswork.
Plex Media Server Logs_2022-09-30_18-28-51.zip (4.8 MB)
here you are ChuckPa
I’m sure chuck will add way more insight than me but for sure you have music work happening on your server (and lots of it). Example below from your log file …
Sep 30, 2022 18:28:49.069 [0x7fb6a5eb3b38] DEBUG - Turbo analysis on modified item 341874 [/home/orbtwin-plex/ORBTWIN-PLEX/musica single artist/Cocteau Twins/(1983) - Head Over Heels/06 - Cocteau Twins - In The Gold Dust Rush.mp3]
Sep 30, 2022 18:28:49.070 [0x7fb6a5eb3b38] DEBUG - Updating media item 341874, size=14066168, metadata_item_id=291007
Sep 30, 2022 18:28:49.070 [0x7fb6a5eb3b38] DEBUG - Updating part with ID=342056 [/home/orbtwin-plex/ORBTWIN-PLEX/musica single artist/Cocteau Twins/(1983) - Head Over Heels/06 - Cocteau Twins - In The Gold Dust Rush.mp3]
Sep 30, 2022 18:28:49.071 [0x7fb6a5eb3b38] DEBUG - Looking for path match for [/mnt/orbtwin-plex/ORBTWIN-PLEX/musica single artist/Cocteau Twins/(1983) - Head Over Heels/07 - Cocteau Twins - The Tinderbox (Of A Heart).mp3]
well
…meanwhile talking with yours, finally the tv-series library ended the scan…now i’m scanning the last various artists library and in the end, my personal photos
…i still don’t know why the previous libraries taking so long, but ended
maybe it would have been better to add the new mount point (/mnt/orbtwin-plex) … scan the library, and finally erase the old path …
…with the photos one, i’ll do that
…sorry my english
thxssss
