Hi
I’m new to Rasplex.
I just installed Rasplex on a Pi2 with a 32gb Class 10. I’m connected to my network via wifi.
From time to time I’m getting disconnected from the server. The wifi seems to be ok, I checked the 2.4ghz networks and seems to be no overlapping with others.
I’m also not able to play anything. It starts and then it stucks. I check the server and the load is minimum.
Where can I start tackling these issues ? Should I downgrade to older versions ?
Looks like a fix is in the works (maybe ready for next version? you’d have to ask): https://forums.plex.tv/discussion/181842/get-directory-failed-0-7-1
Of course, this might not be the exact problem you are having; take a look here to: https://github.com/RasPlex/RasPlex/issues/429
Yes, it is what I’m seeing.
Any workaround ? Do you know if on 0.6.0 it would work ?
I personally did not see the issue in 0.7.0.
The solution was to connect via Ethernet cable and it to a wifi repeater. It solved all my issues.
Yes, I am connected via ethernet, but still get problem recorded here: https://forums.plex.tv/discussion/181842/get-directory-failed-0-7-1
Your issue was different it seems; perhaps bandwidth related.
