Understood, but the concern here is, has that same hotfix applied to 1.29.0 also been applied to 1.29.1, being a newer release. Possibly not, because it’s a different branch and not everything might have been merged yet. So, if I’m running 1.29.0. and I need that hotfix, I’ll get prompted to now install 1.29.1, which doesn’t have it (hypothetically).
So, I’m going mostly by my experience with the SHIELD client, where this exact thing has happened several times this year alone. Fixes that had been in previous stable releases were not merged into the following betas and subsequently also not into newer stables. That was a problem for a lot of us.
Has all been fixed since, it just took a very long time and several bumps. All good on the client side right now. And I appreciate the insight, Chuck. I’m just OCD about build numbers not increasing consistently
Kinda. Its the lack of server side release notes and/or late posting of them. If you look at the announcement page you will see they go from Plex Media Server 1.29.0.6219 to Plex Media Server 1.29.0.6244.
There is no details on what was in Plex Media Server 1.29.0.6244 as none are posted for that build when it went out to beta. Its now available to everyone.
The release notes for Plex Media Server 1.29.0.6219 where posted days after the build was actually pushed out after it was discussed on another thread.
That’s really my comment. Its a lapse from the team and it happens every few months.
Yes, that’s mostly where I’m coming from with the builds, commits, and branches. I get that you guys have your own system, but it makes sense in general.
Yeah, to be clear, build numbers are simply chronological. If we re-run a build of the same commit, it’ll have a new build number. The commit ID is the hex portion after the build number (and is mostly meaningless to anybody without access to the codebase). If we do a new build off an existing release branch (e.g. to backport a fix), it’ll have a newer build number; this is pretty routine and entirely in-line with PMS release procedure, and I don’t have any plans to change that.
I mean, I don’t let PMS update itself anyway. I always do it manually, but sometimes it so happens that something gets released and later pulled, with no notes to go by.
