Versionshistorie
gibt es irgendwo eine Versionshistorie?
z.B. was in der neuen 0.9.6.1 Version geändert wurde?
gibt es wirklich nirgendwo ein changelog bei neuen plex server versionen?
  • NEW: Mac OSX releases are now signed with Developer ID, making it Mountain Lion and 10.7.4 friendly.
    – NEW: We now allow the selection of higher quality streams over 3G with the latest iOS client.
    – NEW: Show “Plex Media Server” when mapping a port via UPnP so it’s nice and pretty on the router.
    – NEW: Plex Media Server is now available for ReadyNAS Duo v2 (ARM).
    – NEW: (DLNA) Support matching headers by regular expression in DLNA profiles.
    – NEW: (DLNA) Allow MIME types to be flexibly overridden by DLNA profiles.
  • FIX: Don’t return empty Silverlight Smooth Streaming (SLSS) manifest files, crashes some clients.
    – FIX: Bad transcoder regression that made remuxing produce ugly artifacts on iOS clients (purple/green).
    – FIX: Transcoder regression where WEB-DL files (and others) could crash the transcoder.
    – FIX: Fixed a bug where a large number of sections could make the server not show up in clients.
    – FIX: Make sure media files sent back can be cached by clients.
    – FIX: Speed up deletion of (especially large) library sections by at least two orders of magnitude. Fast!
    – FIX: Fix for subtitles not being enabled automatically in certain cases.
    – FIX: When we have known foreign audio, and a single unknown subtitle, enable it.
    – FIX: Handle SIGTERM, this is the default kill signal and we should do a proper shutdown.
    – FIX: (Linux) Plex Media Server now bundles rsync.
    – FIX: Don’t allow the OS to go to sleep while streaming media.
    – FIX: Crash that happened when manual NAT setting was used.
    – FIX: Silverlight and Flash channel crashes on Windows and OS X. (e.g. Netflix)
    – FIX: Audio transcoder fixes.
    – FIX: SLSS crash fixed and support for files which claim crazy frame-rates.
    – FIX: Long shutdown on Linux.
    – FIX: Some videos not Direct Streaming with LG TVs.
    – FIX: Crash when /etc/mtab doesn’t exist, use /proc/mounts instead.
    – FIX: /search endpoint supports single quotes in queries.
    – FIX: (DLNA) Fix dimensions for DLNA videos of unknown size.
    – FIX: (DLNA) Don’t error out on unknown DLNA profile tags.
    – FIX: (DLNA) Give up on starting the DLNA server if it fails too many times in a row.
    – FIX: (DLNA) Windows setup now creates a firewall exception for DLNA.
    – FIX: (DLNA) iTunes artist titles was not read correctly by DLNA.
    – FIX: (DLNA) Return a better protocol info for picky clients.
0.9.6.3
New
Allow loading background art for individual seasons (as soon as agents support it).
Added a “By Resolution” filter for browsing your media in a new way.
Added the ability to do remote logging for easier support.
Initial support for new universal transcoder.
(Linux) Builds are no longer compiled with intel specific extensions, should work better for AMD users.
(Linux) Startup/shutdown improved, PID file is written to $PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR
(Linux) We now offer a unRAID package thanks to Dirk Spittler
(DLNA) Enable PN overrides in profiles.
(DLNA) Support for AudioContainers, similar to VideoContainers.
(DLNA) Add profile option to remap blank object id requests
Fixes
Some playback and browse issues in the 0.9.6 series related to database slowness.
Database performance should be much faster overall in this release.
Some media wouldn’t get a thumbnail image.
Fixed redirects in channels, which was breaking lots of channels.
(OS X) Fixed a new issue where occasionally the posters wouldn’t display in the media manager on initial scan.
(Linux) Don’t write settings file every hour if nothing has changed, should prevent disks from spinning up.
(Linux) Use system bundled rsync if available, otherwise fallback on bundled version
Better handling of sleep prevention.
Scanner log was filling up with ‘ignoring atom of size 0’.
Scanner could get stuck using up 100% of CPU.
WMV MediaInfo profile/level not always read correctly
(DLNA) Generic transcodes to mpeg/mpeg2video didn’t work
(DLNA) Transcoding multichannel content to MP3 didn’t work
(DLNA) Generic transcoder fails to encode mpeg4
(DLNA) Server gave access to shared sections, but not myPlex owned sections
(DLNA) Add friendlier error message when port 1900 is in use
(DLNA) Fix stack corruption with seasons > 100 episodes
(DLNA) Apply actual mime types from spec
(DLNA) Identification mechanisms is now case insensitive
(DLNA) Implement friendly name matching for devices without unique user-agent headers
(DLNA) Episodes was displaying out of order
(DLNA) Add profile option to override icon size.
Plex Media Server 0.9.6.7
Fixes
Regression with photo sections showing all photos and not directories.
Correctly read Aperture library file when path is read from pref.
Plex Media Server 0.9.6.6
New
Added (advanced) preference for specifying location of Aperture/iPhone XML paths.
(Linux) Allow syslog logging via environment variable PLEX_MEDIA_SERVER_USE_SYSLOG.
(API) Massive performance improvement for paged data (e.g. for Roku).
(API) Added /library/sections/X/{sorts|filters} endpoints for advanced filtering.
Fixes
Sidecar (e.g. SRT) subtitle files work again.
Windows upload speeds were slow in some cases.
A crash when scanning for plug-ins.
(Mac) Fix some Aperture photos not displaying.
Library timeline could generate blank items occasionally.
Web interface didn’t show added and deleted items properly when scanning.
Don’t pass back bogus blank content ratings.
(Linux) DLNA icon and server name were missing on some platforms.
When overwriting plug-ins, files that don’t exist anymore are deleted.
Handle 302 as well as 301 redirects in the image transcoder.
When scanning files that had already been scanned, they didn’t end up with thumbnails.
Certain image formats (TIFF, BMP, PCX) didn’t get thumbnailed.
Fixed sleep prevention, OS X (and possibly Linux) should sleep now.
(Windows) Fixed a crash on start.
(Synology) DLNA to PS3 wasn’t working.
(DLNA) Memory leak in DLNA server process.
(DLNA) Fixed PS3 audio dropouts.
(DLNA) Fixed evaluation of limitations.
(DLNA) Fixed AAC audio not playing to PS3.
(DLNA) Build-in profile now supports Samsung SmartTVs (thanks, holzi!)
Plex Media Server 0.9.6.5
New
Massive performance improvements in scanning engine.
Other metadata loading/saving performance speedups.
Location header exposed to CORS requests.
Support for virtual scanners, includes an example (iTunes scanner).
Added a new advanced preference (TranscoderDefaultDuration) for specifying default duration for Flash/Silverlight videos.
Added a new advanced preference (TranscoderTempDirectory) for specifying the temporary directory for the transcoder.
(DLNA) Add support for device matching on serial number and manufacturer fields.
Fixes
Music scans refreshed artists/albums for no good reason.
Minor fixes and memory leaks to Quicksilver transcoder.
Do scanning depth-first instead of breadth-first.
Make sure we return not-deleted media items before deleted ones, fixes iOS playback failure in some cases.
Pass back the correct deletedAt time in the metadata item.
Be careful not to overwrite good GUIDs, could lead to episodes losing poster/status when replacing SD ones with HD, e.g.
Fixed a case where certain audio files could fail to analyze, causing repetitive analysis during audio scans.
Fixed a deadlock when calling into the system bundle early in startup.
Fixed a hang scanning DVR-MS content.
Pass more hints along to agents, useful for WTV work.
Browsing by rating wasn’t exactly right.
Failure to log in certain cases.
(DLNA) Getting metadata can result in empty parent ID.
(DLNA) Lack of posters on PS3 (really fixed this time).
(DLNA) Tweak to album art for XBoxes.
Plex Media Server 0.9.6.4
New
Added a new preference option to allow remote networks access to PMS without myPlex.
Add basic CORS support.
(DLNA) profile option to override device fields.
(DLNA) DlnaDeviceDiscoveryInterval can now be set to 0 to disable device detection.
(DLNA) Sections shared from remote servers now includes the servername.
(DLNA) Support matching devices by other device properties than friendlyName.
(DLNA) Ship DLNA profiles with new PMS builds instead of Framework builds.
(DLNA) Emit icons using alternative resolutions.
Fixes
Skip announcing IP addresses from virtual interfaces.
Be faster about extracting thumbnails.
Fix the scanner hanging with 100% CPU scanning some AVIs.
(Win) Fix crash when playing some Flash/Silverlight video.
Notify HTTP clients that we close the HTTP connection.
Only write the amount requsted with HTTP range requests.
Calculate bitrate for videos in a more accurate fashion.
AVIs with broken indexes could hang PMS while trying to create thumbnails.
Scanner is smarter about need to reanalyze media.
A few small memory leaks fixed in scanner.
Crashes scanning some IMG/ISO files.
Overeager timeout when waiting for transcoded content.
iTunes plug-in crashes with invalid input key.
(Linux) Crash related to vmware network interfaces
(Linux) rsync fixes.
(Linux) DLNA crashes on certain systems.
(DLNA) Non-local servers will display server name along with section titles.
(DLNA) Depart the network cleanly when exiting.
(DLNA) PNs not being set for audio, fixes playback on PS3.
(DLNA) Folders now show up in the folders view.
(DLNA) Posters weren’t showing up on PS3.
(DLNA) DLNA server now cleans up correctly when shutting down.
(DLNA) Xbox now supports transcoded jpeg as icons and thumbnails.
(DLNA) Seek seek flags for audio/video (regression).
(DLNA) Metadata for iTunes content now set properly.
Plex Media Server 0.9.6.8
New
Support for PlexPass. See more information here
New mega-awesome web client available at /web. See more information here
Added new (advanced) preferences for enabling/disabling Bonjour/GDM.
(API) Support for JSON in non-channel endpoints.
(API) WebSocket support for sending events to clients.
Fixes
Plex Media Scanner would occasionally crash on exit.
Large reduction in memory/threads usage.
Fix for missing posters when top agent failed.
MP4 files with chapter tracks were analyzed as having subtitles.
Some files (mostly WMV3) could fail to get framerate analyzed.
Make sure photo agents get hit to refresh when scanning.
Always send myPlex username when doing network logging.
Crash when analyzing some TS files.
Be more lenient when parsing URIs which end in & or ?.
(DLNA) Minor fix to Samsung profile.
(Windows) Transcoder can handle RTMP now.
(Linux) ReadyNAS ARM builds working again.
(API) Fixes to preference serialization.
(API) Fix for paging where some items were (partially) missing (and 10% speedup).
(API) Signing into myPlex with ‘+’ signs in email/password was broken.
0.9.6.9
Fixes
(OS X) An annoying crash on start (massive thanks to MarcFBR for helping us track this down).
(Win) RTMP channels weren’t working.
A few minor token-related bugs.
An issue with Internet Explorer and the new Web Client.
0.9.703.317
New
Read some EXIF data for photos and allow filtering on it.
Add support for filtering by resolution.
Improve filtering/sorting options for specific types.
Transcoder now goes idle when it gets ahead, saves CPU, helps multiple sessions coexist.
(DLNA) MPEGTS target supports transcode throttling (lower CPU usage).
(DLNA) MPEGTS target supports audio stream picking and subtitle burning.
Use Plex/Web for the default manager now across platforms (option + click uses old Cocoa manager).
Added Sony 2011 DLNA profile from (thanks to yardco & tcviper).
(API) Add /library/metadata/X/split and /library/metadata/X/merge?ids=a,b,c endpoints.
(API) Add /library/clean/media to delete unused media bundles.
(API) Add /library/clean/bundles to delete unused bundles.
(API) Add ?checkFiles=1 parameter to /library/metadata/X endpoint to check for existence/access for files.
(API) Add /library/metadata/X//[add|remove] endpoints to allow adding/removing tags from items.
(API) Add new unviewedLeafCount/unwatched/unwatchedLeaves filter fields.
(API) Allow >=, <=, and != operators on filter fields.
(API) Added a new /library/onDeck global On Deck endpoint.
(API) Added fledgling new endpoints /transcode/sessions (and corresponding DELETE /transcode/sessions/).
(API) Pass back default sort/direction in /sorts.
(API) Added lots more details to WebSocket notifications.
Fixes
An issue which could result in On Deck items being ordered incorrectly or empty.
Don’t pass back filenames for shared sections.
An issue where season art for date-based shows wouldn’t get loaded the first scan.
A few memory leaks and a socket leak.
An issue which could lead to the media server becoming unresponsive and crashing with no network.
Recently Viewed Show count bumped to 25.
When signing out of myPlex, deregister server in cloud.
Fix some photos not getting thumbnails.
(Windows) Crash when enabling network logging.
Crash analyzing some .TS files.
Speed up photo scanning greatly.
1/16 of the time, we were incorrectly computing OpenSubtitles hashes. Existing ones are repaired.
Attempt to work around newer LG TVs causing PMS to churn with big music sections.
Date-based episodes could be inappropriately merged.
Store format of sidecar subtitles.
Rare issue where HTTP server could stop accepting new connections.
Massive speedup when computing number of watched episodes for a show.
Quitting PMS during startup could lead to a hang.
Move the deletion preference into the library preferences group.
Fix a crash in JSON serialization.
Tweak to phrasing for episode sort list.
Don’t refresh metadata when asked to re-analyze media.
Fix an occasion hang where the media server would become unresponsive to requests.
Watched/unwatched episode counts could get out of sync after a scan.
Filter out non-ASCI characters from EXIF tags.
Scanner crashes analyzing DNG files from Lightroom 4.1
Occasional crash when scanner exits.
Sort files before handing them to the scanners.
Run photo and music analysis two at a time, which speeds things up even more.
Reduction of memory and thread usage.
(DLNA) Fixes for remote/shared server access.
(DLNA) Fix when DlnaDeviceDiscoveryInterval was 0.
(DLNA) Fix issue with XBox360 and MOV files with 64-bit offsets.
(DLNA) OnBrowseMetadata returned wrong content, fixes XBMC playback.
(DLNA) Profile for Panasonic Viera TVs.
(API) Send back titles with library timeline notifications (for Plex/Web).
(API) An issue where WebSocket got closed prematurely.
(API) WebSocket handshake failed when URL has X-Plex-Token in it.
(API) A few WebSockets crashes.
(API) Ensure lastAccessedAt attribute always present for channel listing.
(API) Ensure the endpoint which stops a scan doesn’t return until the scan actually stops.
(API) Return library section XML when POSTing a new section.
(API) Fix a case where library background art endpoint didn’t work.
(API) Allow PUT /library/metadata/X to take multiple IDs.
(API) myPlex signups work again.
(API) Return errors from myPlex when signups don’t work.
(API) When sorting by title, actually use the sort title.
(API) Expose Flash/Silverlight installation state, start state via root XML.
Plex Media Server 0.9.7.7
Fixes
(Linux) Back out of the clugin limit changes, should fix movie matching for Synology / ReadyNAS
(Linux) Pass along LANG variable, to assist agents who need to read filesystem.
(FIX) Don’t limit tag queries by metadata type if we have condition passed in.
(API) Fix when filtering on unwatched in /firstCharacter endpoint.
(API) Allow filter endpoints to use type in queries (e.g. album genres).
