Server Version#:1.43.3.10861
Player Version#:4.160.0
When trying to manage library access for any particular user the library names are not displaying on the library selection screen.
Ive tried accessing these settings on multiple browsers, and directly on the server its self and its the same across the board.
I currently run 2 Plex servers, my main dedicated server and a portable instance on my laptop for travelling. the portable laptop instance doesn’t have this issue, which you can seen the screens. so this issue seems to be specific to my main servers Plex configuration.
through Plex web and locally via 127.0.0.1 and computer.local
all display the same thing.
also to note that if you look at the screenshots, you’ll see 2 servers, one server doesn’t have the issue, so it can’t be a browser display issue, must be some kind of database issue perhaps.
One other observation I should have pointed out is 1 out of 28 library names show up on the affected server, right at the bottom of the list called “Sports”
So I decided to create a new test library to see if that displays, and it does.
