Managed Users always get wrong Language
My problem is that managed users alway get the wrong language on default (German is needed but it’s always English).
On the main Account everything works fine, the language is German and this is always the first language for movies etc…
I already found this Post,were someone else got this problem too, but the solution is not really a solution for me because logging out and logging in again an the clients is not really user friendly.
I hope someone can help me.
Mactracker
if your PMS runs under linux: this is how you can change it yourself by updating database (disclaimer: you do this at your own risk!)
shutdown plex
cd "{PLEX_HOME}/Library/Application Support/Plex Media Server/Plug-in Support/Databases/"
sqlite3 com.plexapp.plugins.library.db
sqlite> UPDATE accounts SET default_audio_language = 'de', default_subtitle_language = 'de', auto_select_subtitle = 1, auto_select_audio = 1 WHERE name = 'myManagedUser'
sqlite> .exit```
restart plex
On Windows you can use MovieFans Database editor
