Hello,
I just installed the latest version of Plex on an Ubuntu 18 server. I logged to this server using my Plex account. Where do I find this server? I can only see my Windows plex server. Where is the place to manage the server you have under one account?
Thanks in advance
If this is a new setup, you need to access the local Plex server to claim the server. You can’t use the hosted version.
I’m accessing the server using the ip and port (http://myip:32400). When I do that I’m asked to login with my Plex account. When I do that I don’t see anything related to this new server.
So after logging in, you go to settings, you see your server on the left. Is there a drop down next to it?
try it in an incognito chrome tab ?
also, once you do get the new server logged in, it should show up as moviefan indicated like @
Same result when I try with the incognito tab. My Panel doesn’t show the new server as the picture you sent me. I added a third server on windows and it works as you said but not the server with Ubuntu 18
If the server is linux,
- Sign out of Plex/web on the local machine
ssh -L 8888:127.0.0.1:32400 ip.addr.of.host (if using windows - perform same ssh tunnel with “Putty”)
- Sign into the ssh shell of the linux box
- Open local browser, incognito window
- http://127.0.0.1:8888/web
With the previous attempts, it’s sometimes better to go into the Linux machine and
- Stop plex
- Delete “Preferences.xml”
- Start Plex
- Remove the previous instance of the server’s name from Settings - Authorized Devices - Servers to ensure no conflicts with Server ID numbers & names.
ah, so your server is not on the local network?
important information you did not mention?
