mrd
December 1, 2019, 8:33pm
1
Server Version#: 1.18.2.2058
I installed a fresh new server, but all I get is “No soup for you, you do not have access to this server”
Wtf, it is a FRESH server, I installed Ubuntu twice now and I can’t set up the new Plex installation!
Any one that know how to fix this? Have re-installed Plex server too, with the same crap.
Please help
mrd
December 1, 2019, 9:20pm
3
It is a local server, installed Ubuntu 18.04
Server IP 192.168.1.10
Everything on the same subnet?
mrd
December 1, 2019, 9:30pm
6
I had to reinstall my server, so I am using the exact same hardware and IP for this server, even had Ubuntu 18.04 on the previous install.
So it is so strange!
Sign the Plex/Web player app out of your Plex account.
Open an incognito window to it.
Is this installed from the Ubuntu store, a Docker, or the native app from Plex.tv/downloads ?
I believe that was what I had to do as well. Using a different browser (Edge) worked too.
Where did you download from / which packaging did you install?
ChuckPa
December 1, 2019, 9:50pm
11
Thanks. The reason I asked is because of where all the data directories are placed.
Each packaging form puts them in different places. Now, if I need give you instructions how to get into it manually, I know I’ll be giving the correct instructions.
dane22
December 1, 2019, 10:15pm
12
PMS logs please, in a zip
mrd
December 1, 2019, 10:32pm
13
Logs.zip (114.4 KB)
Here you go. Time to hit the bed here in Sweden.
Thanks for helping me.
ChuckPa
December 2, 2019, 2:28am
14
Your computer and server are not on the same subnet, which they should be, either by addressing or netmask.
PMS is treating your computer as if remote. Notice the “WAN” designation below.
PMS won’t let itself be claimed directly by a remote client (default security to protect hosted servers).
Server is at:
Dec 01, 2019 20:49:48.128 [0x7f4df4e33b80] DEBUG - Network interfaces:
Dec 01, 2019 20:49:48.128 [0x7f4df4e33b80] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Dec 01, 2019 20:49:48.128 [0x7f4df4e33b80] DEBUG - * 2 eno1 (192.168.1.10) (loopback: 0)
Dec 01, 2019 20:49:48.128 [0x7f4df4e33b80] DEBUG - * 1 lo (::1) (loopback: 1)
Dec 01, 2019 20:49:48.128 [0x7f4df4e33b80] DEBUG - * 2 eno1 (fe80::1a66:daff:fe38:9e7f%eno1) (loopback: 0)
Computer loading the web client (Plex/web) is at:
Dec 01, 2019 20:49:58.579 [0x7f4dc5ffb700] DEBUG - Request: [192.168.2.46:64288 (WAN)] GET /web/js/chunk-2-b2c07a7794e6186e0e42-plex-4.8.4-d12b992.js (3 live) GZIP
Dec 01, 2019 20:49:58.580 [0x7f4dc5ffb700] DEBUG - Final path: "/usr/lib/plexmediaserver/Resources/Plug-ins-e67a4e892/WebClient.bundle/Contents/Resources/js/chunk-2-b2c07a7794e6186e0e42-plex-4.8.4-d12b992.js"
@dane22
I believe you have a cure for this?
mrd
December 2, 2019, 6:29am
15
crap, that’s right, my pc was on my wlan!!! So simple. Thx
system
Closed
March 1, 2020, 6:29am
16
