Manually specifying public port via command line
Hello!
After some tinkering I found out that when i use natpmpc -a 32400 32400 udp 60 -g #.#.#.#, it often selects a different public port number automatically. This is an easy fix as i just specify the public port it wants to use in the web interface for the plex server. However, I was hoping to create a shell script that detects what port natpmpc decides to use then manually specifies the public port through the command line, all automatically. I’m sure i could kick off some kind of selenium based script to go in and change the port number in the web interface, or use xdotool but that could get messed up if window placement/zoom level gets adjusted, I’m hoping to avoid these options if possible.
Is there something that already exists for this? If not can I submit a feature request somewhere?
Seperately, sometimes my dashboard will indicate my 1080p playback is using something crazy like 20 Gbps, is the cause of this known as is there ant workaround?
Thanks!
When I want to find something like that, I simply use a browser, and look at the debugger/network while reproducing
Doing so showed:
https://<IP_OF_PMS>:32400/:/prefs?ManualPortMappingPort=<PORTNo>&X-Plex-Client-Identifier=abcdefg&X-Plex-Token=<MY_TOKEN>
And above was a PUT
