It appears that once a movie has been matched once, unmatching it does not correctly work with the filter unmatched.
My expectation is when unmatching that it is included in the unmatched filter.
Server Version 1.26.0.5715 (docker)
Filter does not work as expected via iOS nor Web player. Seems this has been the case before (or still?).
Continuing the discussion from 'Unmatched' filter not showing unmatched movies:
Server Version#:
Yes, this is expected behaviour and a result of unfortunate naming for the “Unmatch” option.
When you manually unmatch something it actually just matches it to the personal media agent which differs from something that has never been matched before.
There is some discussion around this internally on ways to improve this.
That is unfortunate indeed.
Is there any way I can filter out these “matched to personal media agent” somehow? Or alternatively, is there a way to truly remove a match so it becomes unmatched?
