Matching problems/Help
Hi all, first post and new here. I’ve been using PLEX for many years without any problems but I’ve just added Ghosts (2019) Season 4 to plex which comes with 2021 Christmas special. According to theTVdb.com it should be labelled Ghosts (2019) S00E10 but Plex shows it as just episode 10. I’ve also noticed that Christmas 2020 is showing in Plex as Stunts and visuals now instead of The Ghost of Christmas. Again according to TV.db should be labelled S00E10.
Any idea’s what’s happening or how to fix. I’ve tried rematching but just the same results.
Many Thanks
The Plex TV Series defaults to the aired order of a show as listed on The Movie Database. You can change the episode ordering for your entire library or individual shows (e.g. to TheTVDb (Aired))… or you can name your files according to TMDb instead :wink:
Excellent, Thank you. I’ve named as per The Movie Database and all seems good again.
I think I’ll start using The Movie Database instead of TheTVdb.
