Maximum simultaneous friend connections!
Maximum simultaneous friend connections deleted?
There is no such option anymore…
Is there any reason why this happened?
Settings - Server - Transcoder - ‘Maximum simultaneous video transcode’
This only affects ‘transcoded’ playbacks, not direct streamed ones.
There are no other ‘restriction’ preferences, nor have there ever been.
You probably want something like Tautulli in combination with a script that kills playbacks.
There is a much newer supported script. Please use the one found in Blacktwin’s repo.
https://github.com/blacktwin/JBOPS/blob/master/killstream/readme.md
Wrong phrasing…
I meant “Remote streams allowed per user= 1 or 2 or 3”
Settings – Server – Network – Remote streams allowed per user:
This option no longer exists…
I can still see it.
Did you use to have a Plex Pass?
