MCE Remote and keyboard not 100% with Rasplex on Berryboot
I wasn't sure if this is the right place to post (the issue could be with one of a few parts of the system). My issues is as follows:
Rasplex 0.5.1 running on Rpi 2, installed both directly on a class 10 sandisk ultra 8GB sd and also loaded from USB onto berryboot installed on an identical sd card.
Harmony remote set up as an MCE remote with the big honking official mce remote receiver.
Remote works perfectly with Rasplex installed as standard straight to the SD card. When I install Rasplex on berryboot using the same rasplex image, it boots fine but there seems to be a bit of an issue with the UI. The remote direction buttons, up, down etc. work fine but the OK button doesn't do anything. The LED in the IR receiver blinks to register the press but nothing happens on screen. Also, on the PIN input screen, the remote doesn't work at all. I also noticed that the USB keyboard (which works ok most of the time) cursor keys don't work, numpad buttons don't work, the only way to enter the PIN is using the standard number keys.
Any ideas?
