I have always thought that when “Remote Access” on the “Server Settings” page had a green circle with check mark that this meant your server was accessible from the WAN. At times I am seeing the green check mark but at the same time it say “Not available outside your Network”. If I select “Enable Remote Access” there is a quick unreadable flash of the window being repainted but the window remains the same. That is green check mark and “Not available…”. Also, it does not allow me to select the “Manually specify public port”, which would seem to confirm that Plex believes that “Remote Acess” is disabled despite there being a green check mark.
