Recently the Media Scanner has been crashing during the night and I cant figure out why. What should i bee looking for in the logs?
I can see that I have some crashdumps for the last three nights but they all seem to be binary data and are unreadable to me.
Please paste “Plex Media Scanner.log” to begin with.
Are you using a third party scanner ? is Plex up to date? Under which OS?
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
Okay so here is what i have found.
This crash happens almost every night at the same time around 02:11 during the night. I get this in the windows server 2016 event log:
Timestamp: 2017-12-20 02:11:53
Faulting application name: Plex Media Scanner.exe, version: 1.10.1.4602, time stamp: 0x5a3121fd
Faulting module name: Plex Media Scanner.exe, version: 1.10.1.4602, time stamp: 0x5a3121fd
Exception code: 0xc0000005
Fault offset: 0x0023b4c2
Faulting process id: 0xee0
Faulting application start time: 0x01d3792f8148bb34
Faulting application path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe
Faulting module path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe
Report Id: 6ceee36a-b62f-4d07-8364-24d8e0a11571
Faulting package full name:
Faulting package-relative application ID:
Looking through the Media Scanner logs the log starts at 02:23 but the crash occurred 02:11.
The problems seems to be with Deep Analysis. I found this in the Deep Analysis log:
Dec 20, 2017 02:11:46.996 [3616] DEBUG - [MI] Opening input file: [REDACTED].ape
Dec 20, 2017 02:11:46.997 [3616] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Dec 20, 2017 02:11:46.999 [3616] DEBUG - [FFMPEG] - Format ape probed with size=2048 and score=100
Dec 20, 2017 02:11:46.999 [3616] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 0 bytes read:32960 seeks:3 nb_streams:1
Dec 20, 2017 02:11:47.019 [3616] DEBUG - [FFMPEG] - All info found
Dec 20, 2017 02:11:47.019 [3616] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 496600 bytes read:529560 seeks:3 frames:1
Dec 20, 2017 02:11:51.347 [3144] WARN - Crash: Crash reporting disabled
Dec 20, 2017 02:11:51.348 [3144] WARN - Crash: Crash reporting disabled
Dec 20, 2017 02:11:51.349 [3144] WARN - Crash: Crash reporting disabled
Dec 20, 2017 02:11:51.350 [3144] WARN - Crash: Crash reporting disabled
Yes I have crash reporting off as I am paranoid af. :’(
In the Plex Media Server.log i found this, not sure if it is relevant:
Dec 20, 2017 02:11:46.331 [8300] DEBUG - Butler: Scheduling loudness analysis for album 13631.
Dec 20, 2017 02:11:46.331 [8300] DEBUG - Job running: EAE_ROOT='\\?\D:\TMP-plex\Transcode\Sessions\EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='\\\\?\\C\:\\Users\\Dolan\\AppData\\Local\\Plex\ Media\ Server\\Codecs\\b077134-1269-windows-i386\\' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe --analyze-loudness --force --item 13631 --log-file-suffix " Deep Analysis"
Dec 20, 2017 02:11:50.306 [7480] DEBUG - Butler: Starting delayed task RefreshPeriodicMetadata.
Dec 20, 2017 02:11:51.493 [6792] DEBUG - Auth: authenticated user 1 as supergregg
Dec 20, 2017 02:11:51.493 [7080] DEBUG - Request: [[REDACTED]:65107 (Subnet)] GET /status/sessions (7 live) TLS Signed-in Token (supergregg)
Dec 20, 2017 02:11:51.494 [7080] DEBUG - [Now] Adding 0 sessions.
Dec 20, 2017 02:11:51.495 [6764] DEBUG - Completed: [[REDACTED]:65107] 200 GET /status/sessions (7 live) TLS 2ms 292 bytes (pipelined: 1)
Dec 20, 2017 02:11:51.499 [6764] DEBUG - Auth: authenticated user 1 as supergregg
Dec 20, 2017 02:11:51.500 [7136] DEBUG - Request: [[REDACTED]:65108 (Subnet)] GET /status/sessions (6 live) TLS Signed-in Token (supergregg)
Dec 20, 2017 02:11:51.500 [7136] DEBUG - [Now] Adding 0 sessions.
Dec 20, 2017 02:11:51.504 [6792] DEBUG - Completed: [[REDACTED]:65108] 200 GET /status/sessions (6 live) TLS 3ms 292 bytes (pipelined: 1)
These are the only things happening during this time period in the logs. Everything else is after 02:23.
I can send the memory dump if it will help.
When running on Windows, the following operating system versions are supported:
Windows 7 SP1 / Windows Server 2008 R2 SP1
Windows 8 / Windows Server 2012
Windows 8.1 (with Update) / Windows Server 2012 R2 (with Update)
Windows 10
Windows 2016 is not in the supported OS list and the app crashed so app logs are irrelevant…
Microsoft Visual C++ Runtime Libraries are missing possibly
also put .net in case
Well it has been working fine for a year, I don’t see why it would suddenly start crashing unless something in the application has changed or there is something wrong with the media it is scanning. A windows patch might have changes something, but i doubt it. Everything else works as expected, the media scanner works like it should except during the night at about the same time, every night.
I might have narrowed it down to an album in .ape format. Ill try to remove it from the library and see what happens tonight.
Plex update might need new runtimes
Windows update likelly too…
Try in command line ‘sfc /scannow’ in case of slight os corruption
Nope, not a problem with the system. My guess is there is the problem with the scanner and the probably damaged .ape files.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Plex found an update and its is installing now. Tomorrow we will know.
scanner written in python, shouldn’t crash main Plex’s exe but analysing corrupted files might…
Good luck. Tricky one to solve but maybe you can narrow down a library then file impacted…
As a fellow user of 2016… did you ever find a solution to this? I have notifications that it crashed often, but the server itself doesn’t seem to have any issues (no failed streams etc).
