Media stops playing after a while
Old topic was closed due to inactivity. This was the original text:
Server Version#: 1.42.1.10060
Player Version#: 5.93.2
Hello,
I open this bug now, but this issue plagues me since I started using Plex on this specific device, a Samsung UE50TU7090U TV from 2020.
Only on some media, after some playback time, the buffering icon appears, and after a while I get the “unexpected error” screen. Some media can be played without issues, but other stops playing.
This is not a random issue. The problematic files will always get stuck at the exact same point. The same doesn’t happen with other players.
The Internet connection of course is good on the server and player side.
I have a log but for privacy reasons I don’t want to publicly post it here. Is there a way to share it only with Plex employees?
Thank you.
Follow-up:
Just did a quick test after updating to 1.42.2.10156, and the problem (at least with this specific file) looks related to audio transcoding. If I select the AC3 track, it direct plays the file, while the DTS track needs to be transcoded.
I just played the first few seconds of the file after selecting the AC3 track, and it didn’t stop at the usual place.
The server is more than capable of transcoding audio, so the problem lies in Plex. I can’t tell if the problem is with DTS specifically or with audio transcoding in general.
EDIT: Just tried disabling direct play and direct stream, and it didn’t get stuck at the usual point. Looks like the problem happens when audio is transcoded but video is not.
After updating PMS to version 1.43.0.10492 and the Samsung app to version 5.94.1, I’m still experiencing the same issue.
The issue is still present after updating PMS to version 1.43.2.10687. But the worst thing is that, after 8 months since I first opened this issue, no developer asked for any log. In fact I got exactly zero interactions with Plex staff.
can you provide the smart tv logs after reproducing.
Hi @BigWheel , thanks for your reply. Is there any way to share the logs with the developers without creating a public link?
You can click on my username/avatar to message it directly to me.
Logs sent via DM
Hi @BigWheel, have you looked at the logs? It is still happening on PMS 1.43.3.10828.
Sorry I do not have an updated. I have looked at the logs but I can’t tell what is going on myself. As you mentioned it seem to happened when only audio transcoded it might be something with audio and video getting too out of sync but not sure yet. Sorry I don’t have more info to share.
