Plex freezing when direct streaming video with audio only transcode
Server Version#: 1.29.2.6364 or 1.30.0.6486
Player Version#: Plex for Samsung 5.52.3
Hello,
I’ve got Plex Media Server setup on Windows 10. Most of my files plays fine, but on some cases, when the video file is supported by the TV, but the audio isn’t, it attempts to direct stream the video and transcode the audio and a strange problem happens. The file plays for about 30s-90s then buffers. But it buffers infinitely until i get the “An unexpected playback problem occurred” in about 2 minutes of waiting. I’ve already tested with two types of audio which aren’t supported by my TV: DDP with Dolby Atmos and DTS-HD Master Audio. On both cases, the audio is transcoded to AAC and the problem is identical.
I tried some things to test that it wasn’t a hardware or network issue:
1 - I disabled the “Direct Stream” option on the app. This causes Plex to transcode both video (with same bitrate as original) and audio, which is a lot more hardware intensive then direct streaming video with transcoded audio, as far as I know and evidenced by my CPU/GPU usage. Direct streaming with transcoded audio barely touches my CPU. When I try this and the file doesn’t have gigantic bitrate, it plays normally without buffering at all. When the bitrate is a bit too high, my PC is not strong enough and it buffers, but it buffers normally. It plays a few minutes of video, then buffers a few seconds, continues playing, buffers a little…and the playback never crashes.
2 - I tried reencoding the file with a supported audio file. This causes Plex to direct play the file. My internet connection is pretty good so without the need of transcode, the files play without issues with zero buffering even with very high bitrate files (80+ Mb/s).
I’ve tried checking the server and app logs, but both show zero errors. Could someone help me try to find what is the problem?
Hi, can’t be of any help but I believe I have the same issue as you. Using Plex app on Samsung TV (S95B) I get constant buffering on 4k content that is audio transcoding and hence direct streaming.
When direct streaming 1080p content due to audio transcoding it is fine even at bitrates of 10mbps in my use case. However, when trying to direct steam even low quality 4k content at 3mbps bitrate I get endless buffering.
When trying the same files on my PS5 attached to my TV, while also direct streaming them due to needing audio transcoding, they play fine so issue seems to be localised to Plex app on Samsung TV in my case.
Reported here. Plex employee reproduced the bug, filed an internal case. Then nothing.
Hmm, that’s a bummer. Hope we get a fix soon. I’m surprised I didn’t find your thread. I searched for quite awhile before posting and most were not the same issue or had no answers. But yours is indeed exactly the same.
Today I was testing it again. No freezing so far. Might have been fixed.
Nevermind, buffering after 46 minutes…
I no longer have this problem because I ended up buying an NVIDIA Shield, so it basically direct plays anything. Kinda sad that this problem doesn’t get enough attention though. At least for my use case, it was pratically unbearable, since more than half of the suff I watched ran into this problem.
