Server Version#: 1.41.8
Player Version#: Just using Safari 17.6 on macOS 12.7.6 by double-clicking the “Plex Media Server” app in the Applications folder.
I had a direct-attached RAID called “Scooby” and when that failed I eventually (years later) copied the backup to a new external HDD. I changed the new HDD to have the same name and folder structure as the original. The path to movies should be: /Volumes/Scooby/Plex/Movies but when I access PMS via safari by double-clicking the PMS app I can see that the media for all of the movies that I checked show as “Unavailable”. BTW: the RAID failure happened late 2022 or early 2023… I was trying to recover the actual RAID data since so I could verify that everything was in fact represented. Now I’ve given up on the RAID and I’m ready to move forward with this media from the backup. So, what might be the issue here with the media being unavailable?
Thanks,
Rob
